Select a Numerical Method
Select a numerical method to use when evaluating the Basic approach.
  1. In the Specifications step, Mode column, select a numerical method.
  2. Optional: In the Settings tab, change settings as needed.
  3. Click Apply.
    A run matrix is generated using the numerical method you selected.
Review and edit the run matrix in the Edit Data Summary dialog. For more information, see Edit the Run Matrix.
