Filter Data
The Filter Data tab provides options to filter experimental data. You can use this tab to remove certain frequency, amplitude or preload data from the experiment.
To enable filtering, click Use optional selections for Frequency, Amplitude, Preload.
Once the box is selected, you can use the sub tabs to view and filter data for frequency, amplitude and preload for each direction. You can use multiple filters by defining and accepting filters sequentially.
