Static Stiffness Models
Constant Stiffness Model
Where,
k is the stiffness.
x is the deflection.
Cubic Stiffness Model
| Point | Description | Location on Plot |
| O | Operating point. | The force value, OF, and the slope of the static curve, OS, are selected. |
| Ep | End point for positive deformation. | This is usually the maximum positive deformation in the static test. At EP, the slope of the static curve, EPS, is selected. |
| Rp | Reference point for positive deformation. | As a default, RP = (O + EP)/2. At RP, the force of the static curve, RPF, is selected. |
| EN | End point for negative deformation. | This is usually the maximum negative deformation in the static test. At EN, the slope of the static curve, ENS, is selected. |
| RN | Reference point for negative deformation. | As a default, RN = (O + EN)/2. At RN, the force of the static curve, RNF, is selected. |
Spline Stiffness Model
Spline data is derived by reducing the static data to a curve. A cubic spline is fitted through the measured static data. The spline is then used as the interpolating function for calculating the force at any deflection.
