Mount Limits Block
The [MOUNT_LIMITS] block stores the parameters for mount limits. You can use commas, white spaces or tab characters to separate the data values. The solver obtains the mount limits for a model through the IMPACT function. You can specify limits in the positive and negative travel directions for all 6 directions: X, Y, Z, AX, AY and AZ. For each direction, you specify five parameters.
The following table describes the type and dimension for the input parameters. Abbreviations are [A] = angle dimension, [F] = force, [L] = length, [T] = time.
Parameter Type Translational Units Rotational Units
K Real [F][L-1] [F][L-1][A-1]
E Real - -
C Real [F][T][L-1] [F][L][T][A-1]
D Real [L] [A]
L Real [L] [A]
The example below shows the specification of a Mount Limits block in the .gbi file:
$----------------------------------------------------- MOUNT_LIMITS
[MOUNT_LIMITS]
$   Direction                   K       E     C     D     L
IMPACT_PARAMETERS_TRA_X_POS = 1000.0   1.0   0.0   1.0   1.0
IMPACT_PARAMETERS_TRA_X_NEG = 1100.0   1.1   0.0   1.0   1.0
IMPACT_PARAMETERS_TRA_Y_POS = 1200.0   1.2   0.0   1.0   1.0
IMPACT_PARAMETERS_TRA_Y_NEG = 1300.0   1.3   0.0   1.0   1.0
IMPACT_PARAMETERS_TRA_Z_POS = 1400.0   1.4   0.0   1.0   1.0
IMPACT_PARAMETERS_TRA_Z_NEG = 1500.0   1.5   0.0   1.0   1.0
IMPACT_PARAMETERS_ROT_X_POS = 20000.   1.0   0.0   1.0   1.0
IMPACT_PARAMETERS_ROT_X_NEG = 21000.   1.2   0.0   1.0   1.0
IMPACT_PARAMETERS_ROT_Y_POS = 22000.   1.3   0.0   1.0   1.0
IMPACT_PARAMETERS_ROT_Y_NEG = 23000.   1.4   0.0   1.0   1.0
IMPACT_PARAMETERS_ROT_Z_POS = 24000.   1.5   0.0   1.0   1.0
IMPACT_PARAMETERS_ROT_Z_NEG = 24000.   1.5   0.0   1.0   1.0
