Define Symmetry
Define a symmetry plane on a part.
- The symmetry plane must be orthogonal to the draw direction of the model.
- The symmetry plane must be orthoganal or parallel to any existing symmetry planes in the model.
- If the draw direction is not defined in the model, the sofware automatically defines the draw direction as orthoganal to the symmetry planes.
- If your model requires symmetry planes, define the symmetry planes first, then modify the draw direction as required. When modifying the draw direction, the options that are valid are available in the microdialog. Invalid options are grayed out.
