User sub routines (Groovy): How using paramIOCurrent[k,v]?
In the directory “…\Flux_12.0\Resources\UserFunction\Examples”, open the Flux project “MaterialLaw.FLU”. Save the project under another name in your working directory.
Using a “paramIOCurrent [k, v]”
In this project, follow the instructions above:
Step | Action | |
0 | Delete all project results | |
1 |
2 |
3 |
4 |
5 |
Create a new scenario “MUR_VARIABLE” where ìr would be a physical parameter. In this example, “MU_VAR” take a list of values from 1 to 5000 (See the python script in (6)) (list of values: 1.0, 30.0, 50.0, 100.0, 150.0, 200.0, 300.0, 400.0, 500.0, 600.0, 700.0, 800.0, 900.0, 1000.0, 2000.0, 3000.0, 4000.0, 5000.0) |
6 | ![]() |
7 |
Back to the “ MAT_1” definition and click on the “ Edit user function ” to see and modify into the python editor the groovy sub routine. These files are in the directory : “....YOUR_FLUX_PROJECT.FLU\persistent\groovy ” |
8 |
Type the following groovy code in the sub routine “ compute ”( public void compute()). The parameter user is paramIOCurrent“Mu_var”. Note: In the key “Mu_var” the first letter is writing with an upper
case and the following, in lower case.
9 | ![]() |
10 |
Plot the Flux through the coil versus ìr by ploting the curve of flux through the coil ( )
