Altair Flux™ 2021 Documentation
  1. Home
  2. Flux
    Flux is a finite element software for low-frequency electromagnetic and thermal simulations. Both, 2D and 3D solutions are available...
  3. Physical applications
    Flux allows to model different physical phenomena, and includes various applications (magnetic, electrical, thermal and thermal coupled).
  4. Electric applications: software aspects
  5. Region (for electric applications)
  • User guide
  • What's new?
  • "How to" Documents
  • Flux Supervisor
  • Flux
  • Flux Skew
  • Flux PEEC
  • Material Manager
  • Examples
  • Mementos
  • Macros
  • PyFlux Documentation (Beta version)
  • Flux installation guide
  • Quick Start CDE
  • User guide
    The user guide gives information about principles and how to use Altair Flux™ 2021.
  • What's new?
    See the release notes of the last and previous versions, with the necessary information on new features.
    See a list of documents to understand how to use certain features.
  • Flux Supervisor
    The Flux supervisor allows to run projects, examples, pythons scripts; to configure user preferences; to access tools...
  • Flux
    • General operation
      Here is a presentation of the Flux environment; the project management, the data management, the command language, the formulas and mathematical functions.
    • Construction of a Flux project
      The construction of a Flux project consists of several stages: Geometry → Mesh → Physics → Resolution → Postprocessing; with the possibility to import a CAD file, a mesh, materials...
    • Physical applications
      • Physics: principles
      • Magnetic applications: principles
      • Magnetic applications: software aspects
      • Electric applications: principles
      • Electric applications: software aspects
        • Electric application: definition
        • Region (for electric applications)
          • Electro Static region: about
          • Electro Static volume (3D) / face (2D) region
          • Electro Static face (3D) / line (2D) region
          • Electro Static line (3D) / point (2D) region
          • Electric Conduction region: about
          • Electric Conduction volume (3D) / face (2D) region
          • Electric Conduction face (3D) / line (2D) region
          • Electric Conduction line (3D) / point (2D) region
          • Steady state AC Electric region: about
          • Steady state AC Electric volume (3D) / face (2D) region
          • Steady state AC Electric face (3D) / line (2D) region
          • Steady state AC Electric line (3D) / point (2D) region
          • Transient Electric region: about
          • Transient Electric volume (3D) / face (2D) region
          • Transient Electric face (3D) / line (2D) region
          • Transient Electric line (3D) / point (2D) region
        • Streamer criterion: software aspects
        • Electric applications: sequence of commands
      • Thermal applications: principles
      • Thermal applications: software aspects
      • Coupled applications: principles
    • Circuit and Kinematic Couplings
      Flux is coupled to a circuit context allowing to model the sources of the devices.Flux also allow to model the movement via a kinematic coupling.
    • Co-simulation between Flux and another software
      Flux is able to couple with several softwares allowing to model mutliphysics phenomena.
    • Dedicated couplings
      Several dedicated couplings are implemented in Flux to, carry out vibro-acoustic studies, magneto-thermal studies and more.
    • 3D Overlay
      Flux has predefined models for rotating machines via Overlays allowing to describe a geometry, a mesh and a physics adapted to the wished machine.
    • Flux API
  • Flux Skew
    Flux Skew is a module allowing to facilitate the realization of a quasi 3D or 2 ½ D study starting from a 2D description.
  • Flux PEEC
    Flux PEEC is a 3D modeling module dedicated to electrical interconnections of power electronics devices. It also provides RLC extraction and generation of SPICE-like equivalent circuits.
  • Material Manager
    Flux has a material manager with its own material base.The user can create his own material base and import them into the Flux models to be studied.
  • Examples
    See the lists of examples 2D, 3D, SKEW and PEEC with all available documents and all project and python files.
  • Mementos
    See a list of Memento documents to understand certain Flux features.
  • Macros
    Flux proposes several macros enabling doing actions that are not yet implemented in Flux.
    This documentation deals with the Jython script used in Flux and allows to understand the various structures of entities and functions, and use it in user scripts for example.
    This document provides instructions for Flux installation on supported platforms.
  • Quick Start CDE
    This document guides you through using Computing Distribution Engine.
  1. Home
  2. Flux
  • User guide
  • What's new?
  • Flux Supervisor
  • Flux
  • Flux Skew
  • Flux PEEC
  • Material Manager
  • Examples
  • Mementos
  • Macros
  • Quick Start CDE
Notions
General knowledge:
Region: about
Region: definition (structure)
Regions for Electro Static application
Regions for Electric Conduction application
Regions for Steady state AC Electric application
Steady State AC Electric region: about
Steady State AC Electric volume (3D) / face (2D) region
Steady State AC Electric face (3D) / line (2D) region
Steady State AC Electric line (3D) / point (2D) region
Regions for Transient Electric application
Management
Commands of creation, modification and deletion:
New
Edit
Edit array
Delete / Force delete
Copyright (c) 1983-2020. Altair Engineering, Inc. All Rights Reserved. Contains trade secrets of Altair Engineering, Inc. Copyright notice does not imply publication.
