Reference entities: point, line, plane
Introduction
A reference entity provides some support to the construction of the geometry without being taken into consideration during the mesh and solving operations. These entities are of « NO_EXIST » type.
It exists several “Reference” entities:
- Reference point
- Reference line defined between two points
- Reference plane
When use it?
The table below presents when reference entities can be used.
Reference Entities | When to use it ? |
Reference point |
Reference line |
Reference plane |
How to create it?
The table below presents how the reference entities can be created.
Reference Entities | How to create it? |
Reference point |
The creation of a reference point is identical to the creation of a standard point of Flux. It is necessary to define the coordinate system of creation and coordinates of the point ((X Y Z). To create a reference point:
Reference line |
The creation of a reference line is identical to the creation of a standard line of Flux of segment type. It is necessary to define two points of the segment. These points can be standard points of objects or reference points previously created.
Reference plane |
The creation of a reference plane contains several type of definition (see below)
Type of reference plane
The table below shows different types of creation of a reference plane
Type | Description | Illustration |
Defined by a face (flat) | The reference plane is positioned on the plane of the face which must be flat |
Defined by a point and a line | The reference plane is positioned on the plane describe by the selected point and both points of the selected line (the line must be a segment type) |
Defined by 3 points | The reference plane is positioned on the plane describe by 3 selected points |
Defined by a point and a line perpendicular | The reference plane is positioned on the plane describe by the orthogonal projection on the trajectory of the selected line |
XY plane with offset | The reference plane is positioned parallel to the XY plane with an offset |
XZ plane with offset | The reference plane is positioned parallel to the XZ plane with an offset | |
YZ plane with offset | The reference plane is positioned parallel to the YZ plane with an offset | |
Plane parallel to a plane | The reference plane is positioned parallel to the selected reference plane with an offset | |
Defined by equation | The reference plane is positioned on the plane describe by the equation Ax + Bx + Cx = D. The user must choose coefficients A, B, C and D | |
Defined by angle between two planes | The reference plane is positioned with an angle in relation to the selected reference plane around an axis (the selected line) |
Predefined reference planes
Here is the list of predefined reference plane available at the opening of the modeler:
- XY plane
- XZ plane
- YZ plane
Corresponding coordinate system
For each creation of reference plane (REFERENCEPLANE_1) a corresponding coordinate system (COORDSYS_REFERENCEPLANE_1) is created.
