Merge faces / Merge lines
Before starting
It is necessary to open the context for healing of facet geometry as follows:
Step | Action |
1 |
Pass to the healing mode:
→ | The healing mode for geometry is activated. |
![](Images/image1102518885.jpg)
Merge faces
To merge faces after having imported a file with NASTRAN, PATRAN, IDEAS, or MED format:
Step | Action |
1 |
Activate the command:
→ | A dialog box Merge … is opened. |
2 |
Useless for Merge all faces with Angle Select faces to merge:
3 |
Useless for Merge a list of faces Fill in the text zone:
4 |
Confirm:
→ | The faces are merged. |
→ | A dialog box Merge … is automatically opened. |
5 |
Exit the sequence:
Merge lines
To merge lines:
Step | Action |
1 |
2 |
3 |
Confirm:
→ | The lines are merged. |
4 |
Exit the sequence:
