Flux e-Machine Toolbox: Tests
Running a test
Once the input parameters have been defined, the user can run a test by clicking on
A dialog box appears in which the user must choose the name of the test and click on
List of tests
Once the test running is done, the test appears at the bottom right. Several tests can be run on a same component, in this case they are listed:
Actions on a test
The possible actions on a test run are:
Display:
Display the test results by double-clicking on it or by right click → DisplayA tab with the name of the test is added in the central area, and it is possible to navigate easily using the filters on the left
Close:
Close the display of a test by clicking on the cross of the tab or by right-click
or by right-click →
Close
Delete:
Delete a test by selecting it in the list and by clicking on
or by a right-click → Delete
Export:
Export a test by selecting it in the list and by clicking on
or
by a right-click → Export
Test states
A test can have 3 states:
: the test is
successful-
the test is in progress
: the test is
failed
Export a test
A test can be exported in 3 different formats:
- pdf format for a report (equivalent to all the content of the central area)
- html format for a report (equivalent to all the content of the central area)
- txt format to postprocess data (a text file by quantity)
