Describing active solid conductors (3D)
Classification
In a general approach it is possible to differentiate two types of active solid conductors:
- “open” (ex.: U shaped, or E shaped…)
- “closed” (ex.: toroidal shaped, or…)
These conductors are briefly described hereafter and in more detail in the following paragraphs.
“Open” solid conductor
An “ open ” solid conductor is a conductor with any shape (See example on the opposite figure)
Important: The supplied electric terminals of the solid conductor must be on the edge of the domain (symmetry or periodicity plane).
«Closed» solid conductor
A “ closed ” solid conductor doesn't exist in the real life. A cut is necessary to carry out the connection with the electrical circuit (see figure below).
In Flux 3D, we can model a “closed” solid conductor, superimposing the two electric terminals without a short-circuit.
A “ closed ” solid conductor has its electrical terminals “superimposed” from a geometric point of view. The same geometrical face corresponds to the two terminals of the solid conductor.
| Real conductor | Closed solid conductor of Flux 3D |
Orientation of the current
The orientation of the current is set by:
- the entering and exiting faces of the current, for open conductors
an orientation line
for closed conductors
