Altair Flux™ 2021 Documentation
  1. Home
  2. Flux
    Flux is a finite element software for low-frequency electromagnetic and thermal simulations. Both, 2D and 3D solutions are available...
  3. Circuit and Kinematic Couplings
    Flux is coupled to a circuit context allowing to model the sources of the devices.Flux also allow to model the movement via a kinematic coupling.
  4. Circuit coupling: software aspects
  • User guide
  • What's new?
  • "How to" Documents
  • Flux Supervisor
  • Flux
  • Flux Skew
  • Flux PEEC
  • Material Manager
  • Examples
  • Mementos
  • Macros
  • PyFlux Documentation (Beta version)
  • Flux installation guide
  • Quick Start CDE
  • User guide
    The user guide gives information about principles and how to use Altair Flux™ 2021.
  • What's new?
    See the release notes of the last and previous versions, with the necessary information on new features.
    See a list of documents to understand how to use certain features.
  • Flux Supervisor
    The Flux supervisor allows to run projects, examples, pythons scripts; to configure user preferences; to access tools...
  • Flux
    • General operation
      Here is a presentation of the Flux environment; the project management, the data management, the command language, the formulas and mathematical functions.
    • Construction of a Flux project
      The construction of a Flux project consists of several stages: Geometry → Mesh → Physics → Resolution → Postprocessing; with the possibility to import a CAD file, a mesh, materials...
    • Physical applications
      Flux allows to model different physical phenomena, and includes various applications (magnetic, electrical, thermal and thermal coupled).
    • Circuit and Kinematic Couplings
      • Circuit coupling: principles
      • Circuit coupling: software aspects
        • Operation in the circuit editor context
        • Manipulation of electric circuit components in the circuit editor context
        • The various components of the electric scheme
        • R, L, C components
        • Voltage/current source
        • Finite Element coupling components
        • Switch and Diode
        • Rotating machine components
        • Equipotential point (or potential)
        • Ground
        • Compatibility of components according to the application
        • Manipulation of the electric circuit components in the standard context
        • Description of an electric circuit in the circuit editor context
        • Description of an electric circuit via format XmlCir import
        • Description of an electric circuit via importing of other formats (CCS, TXT, CIF)
        • Verification of the electric circuit
        • Export of electric circuit to a file XCIR or PY
        • Deletion of an electric circuit
        • Management of links between the finite element domain and the electric circuit (2D application)
        • Management of links between the finite element domain and the electric circuit (3D)
      • Kinematic coupling: principles
      • Kinematic coupling: software aspects
    • Co-simulation between Flux and another software
      Flux is able to couple with several softwares allowing to model mutliphysics phenomena.
    • Dedicated couplings
      Several dedicated couplings are implemented in Flux to, carry out vibro-acoustic studies, magneto-thermal studies and more.
    • 3D Overlay
      Flux has predefined models for rotating machines via Overlays allowing to describe a geometry, a mesh and a physics adapted to the wished machine.
    • Flux API
  • Flux Skew
    Flux Skew is a module allowing to facilitate the realization of a quasi 3D or 2 ½ D study starting from a 2D description.
  • Flux PEEC
    Flux PEEC is a 3D modeling module dedicated to electrical interconnections of power electronics devices. It also provides RLC extraction and generation of SPICE-like equivalent circuits.
  • Material Manager
    Flux has a material manager with its own material base.The user can create his own material base and import them into the Flux models to be studied.
  • Examples
    See the lists of examples 2D, 3D, SKEW and PEEC with all available documents and all project and python files.
  • Mementos
    See a list of Memento documents to understand certain Flux features.
  • Macros
    Flux proposes several macros enabling doing actions that are not yet implemented in Flux.
    This documentation deals with the Jython script used in Flux and allows to understand the various structures of entities and functions, and use it in user scripts for example.
    This document provides instructions for Flux installation on supported platforms.
  • Quick Start CDE
    This document guides you through using Computing Distribution Engine.
  1. Home
  2. Flux
  • User guide
  • What's new?
  • Flux Supervisor
  • Flux
  • Flux Skew
  • Flux PEEC
  • Material Manager
  • Examples
  • Mementos
  • Macros
  • Quick Start CDE
Context
The electric circuit editor context
Operation in the electric circuit editor context
Data
The available data:
R, L, C components
Voltage/current sources
Finite Elements coupling components
Switches/semi-conductors
Equipotential point
Ground
Action (1)
Procedure for circuit management:
Export of electric circuit to a file XCIR or PY file
Actions (2)
Procedure for field/circuit coupling management:
Management of coupling between the finite elements domain and the electric circuit (2D application)
Management of coupling between the finite elements domain and the electric circuit (3D application)
Sequencing
The (simplified) sequences of the commands:
2D magnetic applications (with electric circuit) : sequencing of commands
3D magnetic applications (with electric circuit) : sequencing of commands
Reading advice
For the theoretic aspects (principles), refer to chapter Circuit coupling: principles
Copyright (c) 1983-2020. Altair Engineering, Inc. All Rights Reserved. Contains trade secrets of Altair Engineering, Inc. Copyright notice does not imply publication.
