Flux-StarCCM+ co-simulation: about
Introduction
The Flux-StarCCM+ coupling uses the Flux-Flux coupling method realized also for magneto-thermal coupling (but this one is generic and works for other applications). It uses the same communication way with synchronization files and results files.
Implementation
The procedure for coupling Flux and StarCCM+ is as follows:
| Stage | Software | Description |
| 1 |
Flux StarCCM+ |
Prepare the project up to the physics |
| 2 | Flux | Make the materials properties depending on the temperature |
| 3 | Flux | Export the magnetic nodes coordinates |
| 4 | StarCCM+ |
| 5 | Flux |
Create :
| 6 | StarCCM+ |
| 7 |
Flux StarCCM+ |
Solve |
