Extrude lines / Extrude faces
Before starting
It is necessary to have a transformation (created beforehand) and lines / faces to be able to extrude points.
Extrude lines / faces
To extrude lines / faces:
Step | Action |
1 |
Select the lines / faces to extrude:
2 |
Activate the command *:
→ | A new dialogue box is opened. |
3 |
Fill out the fields:
4 |
Validate the information:
→ | The new entities created (points, lines, faces, volumes) depend on the selected option. |
→ | A new dialog box for the extrusion of entities of the same type is automatically opened. |
5 |
Quit the sequence:
![](Images/image303673655.jpg)
![](Images/image1671517719.jpg)
