Paths: about
Definition
A path is a line support, on which the user can evaluate a spatial quantity.
Use
A path is used to plot 2D spatial curves.
Geometric shapes
The path can be as follows:
- rectilinear (straight segment)
- curvilinear (arc of circle, helicoïdal line)
Mesh
The mesh of a path is based on a user-defined discretization: computation points are regularly spaced on the line of the support.
![](Images/image1449338128.jpg)
![](Images/image60342103.jpg)
Types of path
Types of path are as follows:
Type of path | Shape of path | Definition |
path defined by two points |
straight segment / arc of circle helicoïdal line |
two points * (graphical or numerical capture) |
arc defined by three points | arc of circle |
three points * (graphical or numerical capture) |
arc defined by center, radius and angles | arc of circle |
center coordinates, radius, starting angle and ending angle |
parametrized path |
parameter functions |
Parameter setting
The user can use geometric parameters to define the path by the numerical mode.
