Make a copy of the 3D simulation result.
Select the 3D view and 3D view
simulation result (either in the 3D view or the result palette).
On the 3D View contextual tabs set, on
the Result tab in the Manage group, click the
Duplicate component icon.
Tip: You can also use one of the following workflows:
- In the result palette or 3D view, select the
trace. From the right-click context menu, select
Duplicate component.
- Press Ctrl+K.
