Create a POSTFEKO report template when it is required
to create consistent reports. The reports are generated from a preconfigured POSTFEKO report template using styling from a Microsoft PowerPoint
or a Microsoft Word template.
On the Reporting tab, in the
Reports group, click the Define template icon.
Figure 1. The Define report template dialog.
In the Document typedrop-down list, select one of the following:
MS Word (*.docx *.doc)
MS PowerPoint (*.pptx)
In the Template field, specify the Microsoft template to
be used for the report generation.
Click Next.
Figure 2. The Define report template dialog.
In the Image formatdrop-down list specify the image format.
In the Export sizedrop-down list select the export size of the images used in
the report.
In the table specify the POSTFEKO graph or 3D view for each tag used in the Microsoft template.
Click Next > Done.
Tip: View the report template in the project browser under Report
templates.
[Optional] Modify the report template.
Reports group, click the Modify template icon.
