Modify or remove the legend entry text.
Select the graph where you want to modify the legend text
and click the trace.
On the Cartesian
context tab, on the Display tab, in the Legend group, click the
Trace text
icon.
Figure 1. The Legend entry settings dialog.
Specify the trace text for the graph legend.
Clear the Auto check box.
In the Legend text field, enter the trace text
Tip: You can also use one of the following workflows:
- In the result palette or 3D view, select
the trace. From the right-click context menu, select
Trace text.
- Press Shift+F2.
To remove a trace from the legend, select one of the following:
- Clear the Legend entry visible check
box.
- Clear the Auto check box and delete the content
in the Legend text field.
Use the trace label (displayed in the result palette) as the
legend text.
Select the Use trace label text check box.
Click OK to apply the changes and to close the
dialog.
