Locate specific mesh elements by element number (ID) in the 3D view.
When a warning or error message is obtained during the solution of a model, in some
cases the message is related to a specific mesh element.1. With the Find
elements tool, you can find and view the location of the mesh
element.
On the 3D View contextual tabs set, on the
Mesh tab, in the Tools
group, click the Find elements icon.
From the Element typedrop-down list, select the type of mesh element you want to
find.
In the Element ID(s) field, enter the element number(s)
you want to find.
Tip: Search for multiple elements by separating the element numbers
with a comma.
Figure 1. Finding two mesh triangles by ID (number).
[Optional] To retain the annotations, click Add
annotation(s).
Click Close to close the dialog.
1 The mesh element ID(s) would
be given in the .out file
