Gain insight into a result by animating a result.
For this example, the result is animated over time step. A
time signal and time result are required to animate over time.
Select the 3D view and the result that you want to
animate.
On the 3D View
contextual tabs set, on the Animate tab, on the
Settings group, click the
Type icon. From the drop-down list, select the
Time step icon.
On the 3D View contextual tabs set, on the Animate tab, on the Control
group, click the
Play icon.
Note: To stop the animation, click the
Play icon.
