Add a result to a 3D view or graph using the project browser.
Select the 3D view or graph where you want to add a simulation
result.
In the project browser, select the model.
In the model browser, click the
Results tab. Use one of the following
workflows:
- Drag a result onto the 3D view or graph.
- From the right-click context menu and select Add to active
window or click Add to new to create
a new 3D view or graph.
Figure 1. Example of adding a far field result from the project browser and selecting a result.
