Launching EDITFEKO (Linux)
There are several options available to launch EDITFEKO on Linux.
Launch EDITFEKO using one of the following workflows:
  • Open EDITFEKO using the Launcher utility.
  • Open a command terminal. Use the absolute path to the location where the EDITFEKO executable resides, for example:
    /home/user/2021/altair/feko/bin/editfeko
  • Open a command terminal. Source the “initfeko” 3D view using the absolute path to it, for example:
    . /home/user/2021/altair/feko/bin/initfeko
    Sourcing initfeko ensures that the correct Feko environment is setup. Type editfeko and press Enter.
    Note: Take note that sourcing a script requires a dot (".") followed by a space (" ") and then the path to initfeko in order for the changes to be applied to the current shell and not a sub-shell.
