Defining a Workplane to Use in Geometry Creation
Add a new workplane to the model for geometry creation.
On the Construct tab, in the Define group, click the
Add workplane icon.
Under Origin, enter the position of the workplane using
one of the following methods:
- Enter the coordinates for the origin manually.
- Use point entry to enter the coordinates for the origin from the 3D view.
Specify the rotation of the workplane using one of the following
workflows:
- Specify the U-Vector and V axis vectors.
- Click one or a combination of the following under Rotate
workplane:
and
or specify the angles.
- In the Label field, add a unique label for the workplane.
Select one of the following workflows to close the dialog.
- To create the workplane and close the dialog, click OK.
- To create the workplane, but keep the dialog open to add a second workplane, click Apply.
