To solve a model with the uniform theory of diffraction (UTD), you must activate UTD for each relevant
face.
Select the face (or faces) in the in the 3DÂ view or in the
details tree that you want to solve with PO.
In the details tree, from the right-click context menu, select Properties.
On the Face properties dialog, click the
Solution tab.
Under Solve with special solution method, from the
drop-down list, select Uniform theory of
diffraction (UTD).
Click OK to save the face properties and to close
the dialog.
