Sweeping Geometry Along a Path Apply the sweep along a path operation to curves to create surfaces, and to surfaces to create solids. Select the geometry part that you want to sweep. On the Construct tab, in the Extend group, click the Path sweep icon. Figure 1. The Create path sweep dialog. Select the path to sweep along. The selected geometry is swept along the specified path.
