Stitching Sheet Parts Apply the stitch operation to ensure electrical connectivity for unconnected sheet parts. Select the sheet parts that you want to stitch. On the Construct tab, in the Modify group, click the Stitch icon. Figure 1. The Stitch parts dialog. In the Tolerance field, specify the range in which adjoining faces are stitched. Click the Create to stitch the faces and to close the dialog.
