Processing math: 100%
Transmission and Reflection Coefficients
Calculate the properties of frequency selective surfaces (FSS) in a multilayer scattering scenario by using transmission and reflection coefficients for plane waves. Use in conjunction with periodic boundary conditions (PBC), multilayer planar Green's functions or infinite planes for a more efficient solution.
Note: Only a single plane wave is supported (no additional sources are allowed) when requesting transmission / reflection coefficients.
The model must either contain:
  • planar multilayer substrate without any other geometry / mesh in the model
or
  • a 2D periodic boundary condition (PBC).
The transmission coefficient is defined as:
(1) τ=EtEi
and the reflection coefficient:
(2) ρ=ErEi
Figure 1. A plane wave interacting with a planar structure.
