Edge Ports
Edge ports can be applied to an edge defining the boundary between two sets of faces.
Faces referenced in the port definition must belong to the same part for a valid port definition.
Note: An edge port can be applied to a single UTD
face, but the faces on the other side of the defined port must be standard MoM faces.
Figure 1. The edge port in the 3DÂ view. The side of the positive faces is indicated with a red cylinder and the negative faces with a blue cylinder.
