Adding Coordinates from the 3D view to a Dialog Using Point Entry
Use point entry to add coordinates from the 3D view to fields on a dialog.
As an example, specify the base corner of a cuboid by snapping to a point in the 3D view and use point entry to add the coordinates to the dialog.
