To solve a model with the volume equivalence principle (VEP), you must activate VEP
for each relevant region.
Select the region (or regions) in the in the 3DÂ view or in
the details tree that you want to solve with the VEP.
In the details tree, from the right-click context menu, select Properties.
On the Region properties dialog, click the
Solution tab.
Under Solve with special solution method, from the
drop-down list, select MoM/MLFMM with volume
equivalence principle (VEP).
Click OK to save the region properties and to
close the dialog.
