Mesh Quality
This option controls the quality of the mesh.
- Mesh size growth rate
- This option controls how quickly the mesh size changes. Fast allows an abrupt jump from small to large elements, while for Slow, each adjacent triangle will increase in size with less than twice the size of its previous neighbour.
- Enable mesh smoothing
- This option applies an additional smoothing algorithm that results in better quality mesh
but will increase the time to mesh the model. Tip: This algorithm is usually not time-consuming and it is recommended to use the additional smoothing.
