Launching CADFEKO (Linux)
There are several options available to launch CADFEKO in Linux.
Launch CADFEKO using one of the following
workflows:
- Open CADFEKO using the Launcher utility.
- Open a command terminal. Use the absolute path to the location where the
CADFEKO executable resides, for
example:
/home/user/2021/altair/feko/bin/cadfeko
- Open a command terminal. Source the “initfeko” script using the absolute path to
it, for
example:
Sourcing initfeko ensures that the correct Feko environment is configured. Type cadfeko and press Enter.. /home/user/2021/altair/feko/bin/initfeko
Note: Take note that sourcing a script requires a dot (".") followed by a space (" ") and then the path to initfeko for the changes to be applied to the current shell and not a sub-shell.
