Define an aperture or slot in a ground plane using aperture triangles.
Select the face where you want to apply the aperture triangles.
From the right-click context menu, select
Properties.
On the Face properties dialog, click the
Solution tab.
Under Solve with special solution method, in the
drop-down list select Planar Green's function
aperture.
Click the OK to apply the aperture triangles and
to close the dialog.
