Defining PCB Current Data from File
Import printed circuit board (PCB) current data from a PollEx radiated emission interface (.rei) file to create a PCB current data definition. Use the current data definition when defining an equivalent source.
  1. On the Construct tab, in the Define group, click the  Field/current data icon. From the drop-down list select  Import PCB current data from file.
    Figure 1. The Import PCB current data dialog.
  2. In the Current data (*.rei) file field, browse to the file location of the .rei PCB current data file that was written out by PollEx.
  3. In the Label field, specify a unique label for the PCB current data.
  4. Click Create to define the PCB current data and to close the dialog.
