View the model using visualisation tools in POSTFEKO
to ensure the model was created as intended.
Ensure the horn model is open in the 3D view.
By default the mesh edges of the model is not displayed in the 3D view.
Enable the mesh edges.
On the 3D View
contextual tabs set, on the Mesh tab, in the
Visibility group, click the Metal icon. From the drop-down list, select the
Edges check box.
Disable the display of the symmetry planes.
On the 3D View
contextual tabs set, on the Display tab, in the
Method display group, click the Symmetry icon.
Sources in the model are displayed by default.
Disable the display of sources in the model.
On the 3D View
Entities group, click the Sources icon.
To view the full-length horn in the 3D view, zoom the
horn to the extents of the window.
Zoom to extents of the 3D view using one of the following
workflows:
On the View tab, in the
Zooming group, click the Zoom to extents icon.
Press F5 to use the keyboard
shortcut.
Enable the tick marks on the axes.
On the 3D View
Axes group, click the Tick marks icon.
Use the distance measurement tool to validate the dimensions of the horn.
On the 3D View
Tools group, click the Measure distance icon.
On the Measure distance dialog, ensure the
Point1 field is active.
Note:An active field allowing point-entry is indicated by a
yellow background.
In the 3D view, press Ctrl+Shift+left click on the first point.
