Working with states and pseudo-states
A state represents a distinct context for the behavior of an object. A state can be active or inactive during execution. A state becomes active when it is entered as a result of a transition, and becomes inactive if it is exited as a result of a transition. A state can be exited and entered as a result of the same transition (referred to as self-transition).
State
composite state
A composite state is a state with one or more regions.
final state
Completion of a region.
state
A state that does not have regions or hierarchy. It is sometimes referred to as a simple state.
submachine state
A submachine state contains nested states. The submachine state lets you divide a complex start chart into subsystems.
A pseudo-state refers to any element in the state chart that will not be occupied for any duration. Pseudo-states are typically used to connect transitions into more complex state transition paths.
Pseudo-state
choice
Splits transition into multiple paths
deep history
Represents the most recent active configuration of the composite state
entry point/exit point
Allow connections from a state to a submachine state
fork
Allows entry into multiple regions of a composite state
history
Represents the most recent active substate of its containing state
initial state indicator
Represents the source for a single transition
join
Exits multiple regions of a composite state
junction
Chains together multiple transitions
terminate
Causes the state chart to terminate all execution
