Using the Watch State Chart variable panel
You can watch the evolution of state chart variable values during the simulation by selecting available variables and adding them to the Watch State Chart variables panel.
The Watch State Chart Variables panel appears using the State Charts > Quick Watch command.
The Watch State Chart Variables panel is empty by default. You can add and remove variables from the current model using the toolbar buttons in the upper right corner of the window :
To
Do This
Add a variable to watch
1.     Click on .
2.     The Select Variable window is displayed listing all available variables.
3.     Select a variable in the tree and click OK.
The selected variable is added to the Watch State Chart Variables panel
Remove a variable from watch
1.     Select a variable in the Watch State Chart Variables panel and click on .
2.     The variable is removed from the panel.
You can alternatively press the DEL key to remove a selected variable.
Add all variables
•      Click on  .
All variables available in the model are added automatically to the Watch State Chart Variables panel.
Remove all variables
•      Click on .
All variables listed in the Watch State Chart Variables panel are removed.
