プリファレンスダイアログ
プリファレンスダイアログから、Composeのワークスペース、キーボードショートカット、ユーザーインターフェースツールなどのプリファレンス設定を調整できます。
ファイルメニューからプリファレンスをクリックしてダイアログを表示します。
Define a Preference Setting
Keyboard Shortcuts
From the Preferences dialog, select Keyboard Shortcuts to view the default, editable shortcuts available in Compose.
- Cycle through recent files
- Ctrl+Tab
- Indent block
- Tab
- Remove indent from block
- Shift+Tab
- Delete to start of word
- Ctrl+Backspace
- Delete to end of word
- Ctrl+Delete
- Delete to start of line
- Ctrl+Shift+Backspace
- Delete to end of line
- Ctrl+Shift+Delete
- Go to start of document
- Ctrl+Home
- Extend selection to start of document
- Ctrl+Shift+Home
- Go to start of display line
- Alt+Home
- Go to end of document
- Ctrl+End
- Extend selection to end of document
- Ctrl+Shift+End
- Go to end of display line
- Alt+End
- Line cut
- Ctrl+L
- Line copy
- Ctrl+Shift+T
- Line delete
- Ctrl+Shift+L
- Line transpose with previous
- Ctrl+T
- Selection duplicate
- Ctrl+D
- Previous word (Shift extends selection)
- Ctrl+Left
- Next word (Shift extends selection)
- Ctrl+Right
- Rectangular block selection
- Alt+Shift+Movement
