Curve Editor
The Curve Editor is a utility to create and edit curves that serve as input into the SignalGenerator block.
The Curve Editor lets you manually design a signal by moving the curve of the time signal on a grid or entering X and Y coordinate values.
Designing Signals with the Curve Editor
Launch the Curve Generator from the SignalGenerator block to design or modify a signal.
