Selecting a Data Table
You can select from a list of available data tables using the dropdown Data Tables menu.
After you select a specific Data Table from the list, the screen displays all columns in the associated data table.
Panopticon Designer (Desktop) groups Data Tables into three categories:
Data Tables saved into the open Panopticon Designer (Desktop) Workbook
Data Tables published to the Panopticon Visualization Server
Data Tables saved to disk
You can proceed to add Data Visualizations to a Dashboard.
