Splits the value of a single address column into its component address or postal parts.
You can either:
right-click on a Date/Time field
click the drop down of a Date/Time field
then select Split... in the context menu that displays.
The Split dialog displays.
Select Regular Parts.
Enter the value or click in Sample Row to select the row number that a sample of the split definition that will be displayed in the Result Column box below.
Check any of the Time Bucket boxes that you want to use for the split columns:
Year
Month
Day
Hour
Minute
Second
Date
Time
DayofYear
Qtr
HalfYear
Check the Remove Original Column box to delete the original column and just display the split columns instead.
Click OK. The new columns of the components selected from the split are displayed.
NOTE: You can opt to change the data type or data formats of these split columns.
