Change Data Format
Data format of Numeric fields can be modified as they are displayed in dashboards, either in tables, filters, or in visualization pop-up details.
Changing Data Format
You can either:
right-click on a Numeric field
click the drop down
of a Numeric field
then select Change Data Format in the context menu that displays.
The Change Format dialog displays.
Select the new numeric display format. Refer to Numeric Display Format for more information.
Click Reset if you want to revert back to the default format.
Click OK.
