R & Python Transforms for Streaming Data
R and Python transforms can be performed for streaming data.
Refer to R Transform or Python Transform for more information.
NOTE:
When used with streaming data sources (e.g., message bus), the Real Time Limit of a streaming data source should be set to a value longer than the time taken to perform the R or Python data transform.
For example, if the transform operation takes 2 seconds, the Real Time Limit should be set to 2500 milliseconds.
