Network Graph Settings
These are divided into three tabs:
General
Setting
Node Min Radius
The minimum radius of each node.
Node Max Radius
The maximum radius of each node.
Min Edge Thickness
The minimum thickness of each edge that represents the connection between nodes.
Max Edge Thickness
The maximum thickness of each edge that represents the connection between nodes.
Show Edge Directions
Whether to display the direction of the edges.
NOTE: The default Title Style is set to Full Path.
Synchronization
Filters
Refer to Visualization Static Filter for more information.
