Add a Data Source
When creating a new data table or editing an existing one, you can add a new data source.
Adding a Data Source
You can add a data source in the Edit Data Table view either by:
Clicking the
button in the Data Sources area.
The Connect to Data dialog is displayed.
Then select a data source in the list. Click OK or Open depending on the data source you selected.
Dragging other data sources in the Desktop of your computer and dropping to the Data Sources area, as long as they are supported Panopticon Designer (Desktop) connector files:
.accdb
.accde
.csv
.dwx
.exd
.exw
.json
.mdb
.mde
.svg
.xls
.xlsm
.xlsx
.xml
