Altair® Panopticon
Defining Action Parameter Properties
For each parameter added or defined in the actions, you can set their Value Source:
q  Current Value
The current value of the parameter is used.
 Interactive
Allows values to be entered when the action is executed.
q  Constant Value
Allows the constant value of the parameter to be defined.
q  Parameter
Allows the selection of the source parameter.
