Altair® Panopticon
Context Menu
Panopticon provides a right-click Context Menu in each visualization.
Visualization Context Menu
Visualization context menu on the Numeric Axis
Time Series Visualization Context Menu on the Time Axis
Table visualization context menus depending on where you click on the visualization
The visualization context menu options include:
Setting
Automatic Parameterization
Run an automatic parameterization.
Action
Run a workbook action on the visualization.
New Alert
Create an alert.
Visualization Filtering
Allows visualization filtering. Options include:
·         Include Item
·         Exclude Item
·         Exclude Time
·         Clear
Drilling
Allows drilling into visualizations. Options include:
·         Drill Down
·         Drill Up
·         Drill to Top
Data Export
Allows exporting of data. Options include:
·   Copy Image
·   Copy Data
·         Export Raw Data
·         Copy Cell Data
Zooming
Allows zooming in and out of visualization sections.
Set Axis Range
Allows setting the numeric axis range (Dynamic or Fixed).
Show Shelves
Turned off by default. Check to allow the cross tab, breakdown, and variables to be displayed.
Pinning
Allows pinning of the Details pop-up. Options include:
·         Pin Details
·         Unpin
·         Unpin All
The additional time series visualization context menu options include:
Setting
Set Snapshot Here
Available in the time series visualization context menu when the Snapshot Grid Line is rendered or set to Dotted, Dashed, or Solid in the Time Axis variable.
Set Axis Range
Allows setting of the time axis range:
·         Min Range
The minimum time axis range. Supported units are milliseconds, seconds, minutes, hours, days, months, quarters, and years.
·         Increment Step
Controls how much the time axis span is extended at the point when the latest value is at the end of the current time axis span. Supported units are milliseconds, seconds, minutes, hours, days, months, quarters, and years.
This setting helps in seeing how a real-time data set grows from left to right along the time axis, giving a better impression and understanding of the progress..
The additional Table visualization context menu options include:
Setting
Adjust Columns
Adjust column width in the table visualization.
Hide / Unhide Columns
Hide or display columns in the table visualization.
Show Hierarchy Column
Display the hierarchy column.
Expand / Collapse Hierarchy
Expand or collapse sections of the hierarchy.
Show Grand Total
Determines whether the Grand Total aggregate row is shown in the table.
Show Sub Totals
Determines whether Sub Total aggregate rows are shown in the table.
Show <Column>
Display the breakdown column.
