Altair® Panopticon
Latitude & Longitude Variables Configuration
The Longitude and Latitude variables are available in the Map Plot visualization. These coordinates are used to locate a place on Earth’s surface.
The configuration pane for Lat and Long Variables is the same as for the Size variable.
NOTE
Default aggregation for the Latitude and Longitude variables are:
·         Mean for numeric columns.
·         Calculation for calculated columns.
·         External if data table contains external aggregates for the column.
