View Cuts by Step
This command plots the amplitude (dB or nat) or the phase of the fields computed for each step of the simulation periodical structure. The user can select different components to view.
Figure 1. View cuts by step
It is also possible to delete the selected trace of the list with the Remove Series button. The display option allows to change the color of the series and display points. The Import Series and Export Series buttons are used for importing and exporting the selected series in List of Series to a data text file.
