Selecting the Insert Part
If the extrusion has a metal insert, that condition is applied using insert parts. Inserts are modeled using BCs (the interface condition between insert and the polymer).
  1. From the Polymers ribbon, Process Data tools, click the Insert tool.
  2. Select the insert part.
  3. In the microdialog, enter the process conditions.
    Note: Inspire Extrude will adjust the length of the insert to match the length of the profile.
